Saltar al contenido principal
Acer Aspire E1-510P-4637 Keyboard Replacement
Qué necesitas
  1. Acer Aspire E1-510P-4637 Keyboard Replacement, Battery: paso 1, imagen 1 de 1
    • To release the battery, depress the battery release with a nylon spudger. Hold the latch down and slide it over.
  2. Acer Aspire E1-510P-4637 Keyboard Replacement: paso 2, imagen 1 de 1
    • Firmly grab hold of the battery and slide it out of the laptop.
  3. Acer Aspire E1-510P-4637 Keyboard Replacement, Hard Drive: paso 3, imagen 1 de 1
    • Remove the M2.5x8 screw with a PH1 screwdriver.
  4. Acer Aspire E1-510P-4637 Keyboard Replacement: paso 4, imagen 1 de 1
    • Use the plastic opening tool to pop off the small back cover.
  5. Acer Aspire E1-510P-4637 Keyboard Replacement: paso 5, imagen 1 de 1
    • Use a PH0 Phillips screwdriver to remove the screw securing the hard drive.
  6. Acer Aspire E1-510P-4637 Keyboard Replacement: paso 6, imagen 1 de 2 Acer Aspire E1-510P-4637 Keyboard Replacement: paso 6, imagen 2 de 2
    • Use a nylon spudger to slightly pry up the hard drive near the screw holes.
  7. Acer Aspire E1-510P-4637 Keyboard Replacement: paso 7, imagen 1 de 3 Acer Aspire E1-510P-4637 Keyboard Replacement: paso 7, imagen 2 de 3 Acer Aspire E1-510P-4637 Keyboard Replacement: paso 7, imagen 3 de 3
    • Grab hold of the plastic tab and pull the hard drive away from the connectors. This will release the hard drive.
    • The hard drive connector is fragile. Handle with care.
  8. Acer Aspire E1-510P-4637 Keyboard Replacement, Keyboard: paso 8, imagen 1 de 1
    • Remove the fourteen M2.5x8 screws highlighted in the picture with a PH0 Phillips screwdriver.
  9. Acer Aspire E1-510P-4637 Keyboard Replacement: paso 9, imagen 1 de 1
    • Slide out the disk drive tray.
  10. Acer Aspire E1-510P-4637 Keyboard Replacement: paso 10, imagen 1 de 1
    • Use the plastic opening tool to gently pry open the laptop.
  11. Acer Aspire E1-510P-4637 Keyboard Replacement: paso 11, imagen 1 de 3 Acer Aspire E1-510P-4637 Keyboard Replacement: paso 11, imagen 2 de 3 Acer Aspire E1-510P-4637 Keyboard Replacement: paso 11, imagen 3 de 3
    • Rotate the back cover up a little to reveal the cables connected to the motherboard.
    • Unplug the cables by sliding them out of their receptacle.
    • The connectors are very small and fragile. Handle with care.
  12. Acer Aspire E1-510P-4637 Keyboard Replacement: paso 12, imagen 1 de 1
    • Remove the four center panel M1.6x3 screws with a PH0 Phillips screwdriver.
    • Remove the two M2x3 screws with a PH0 Phillips screwdriver.
  13. Acer Aspire E1-510P-4637 Keyboard Replacement: paso 13, imagen 1 de 3 Acer Aspire E1-510P-4637 Keyboard Replacement: paso 13, imagen 2 de 3 Acer Aspire E1-510P-4637 Keyboard Replacement: paso 13, imagen 3 de 3
    • Use the plastic opening tool to slide the metal part out to release it from the retaining tabs.
  14. Acer Aspire E1-510P-4637 Keyboard Replacement: paso 14, imagen 1 de 2 Acer Aspire E1-510P-4637 Keyboard Replacement: paso 14, imagen 2 de 2
    • Peel off the foil adhesive stuck to the keyboard.
  15. Acer Aspire E1-510P-4637 Keyboard Replacement: paso 15, imagen 1 de 1
    • Remove the keyboard.
Conclusión
2 personas más completaron esta guía.
Caleb lindsay
Miembro Desde 04/11/16
778 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 34-15, Maness Spring 2016 Miembro de Cal Poly, Team 34-15, Maness Spring 2016
CPSU-MANESS-S16S34G15
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 13
Todo El Tiempo: 1,180
