Saltar al contenido principal
Acer Aspire E1-510-2500 RAM Card Replacement
Qué necesitas
  1. Acer Aspire E1-510-2500 RAM Card Replacement, Battery: paso 1, imagen 1 de 1
    • Ensure that your laptop is completely switched off, and disconnected from the power source.
    • Flip the laptop so that the base of the laptop is facing up.
  2. Acer Aspire E1-510-2500 RAM Card Replacement: paso 2, imagen 1 de 2 Acer Aspire E1-510-2500 RAM Card Replacement: paso 2, imagen 2 de 2
    • Insert a spudger into the battery release latch.
    • Slide the battery release latch to the right, this will eject the battery for safe removal.
  3. Acer Aspire E1-510-2500 RAM Card Replacement: paso 3, imagen 1 de 2 Acer Aspire E1-510-2500 RAM Card Replacement: paso 3, imagen 2 de 2
    • Carefully slide the battery out of the battery's home.
  4. Acer Aspire E1-510-2500 RAM Card Replacement, RAM Card: paso 4, imagen 1 de 2 Acer Aspire E1-510-2500 RAM Card Replacement, RAM Card: paso 4, imagen 2 de 2
    • Using a Phillips 1 screwdriver, remove the 9 mm screw which secures the back panel.
  5. Acer Aspire E1-510-2500 RAM Card Replacement: paso 5, imagen 1 de 2 Acer Aspire E1-510-2500 RAM Card Replacement: paso 5, imagen 2 de 2
    • Use a plastic opening tool to carefully pry the back panel from its home.
    • When reassembling, insert the panel from the edge opposite the screw first.
  6. Acer Aspire E1-510-2500 RAM Card Replacement: paso 6, imagen 1 de 3 Acer Aspire E1-510-2500 RAM Card Replacement: paso 6, imagen 2 de 3 Acer Aspire E1-510-2500 RAM Card Replacement: paso 6, imagen 3 de 3
    • Locate the tabs on either side of the RAM card.
    • Push out on both tabs simultaneously to release the RAM card.
    • The RAM card should raise slightly at the unattached edge.
  7. Acer Aspire E1-510-2500 RAM Card Replacement: paso 7, imagen 1 de 2 Acer Aspire E1-510-2500 RAM Card Replacement: paso 7, imagen 2 de 2
    • Carefully remove the RAM card from its home.
Conclusión
Una persona más ha completado esta guía.
Sebastian Taylor
Miembro Desde 10/19/17
733 Reputación
6 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 9
Todo El Tiempo: 592
