Saltar al contenido principal
Acer Aspire E1-470P-6659 Motherboard Replacement
Qué necesitas
  1. Acer Aspire E1-470P-6659 Motherboard Replacement, Battery: paso 1, imagen 1 de 1
    • Turn off the laptop and disconnect all device cords.
  2. Acer Aspire E1-470P-6659 Motherboard Replacement: paso 2, imagen 1 de 1
    • Flip the laptop over so the bottom is facing you.
  3. Acer Aspire E1-470P-6659 Motherboard Replacement: paso 3, imagen 1 de 3 Acer Aspire E1-470P-6659 Motherboard Replacement: paso 3, imagen 2 de 3 Acer Aspire E1-470P-6659 Motherboard Replacement: paso 3, imagen 3 de 3
    • Use your finger or a spuger to pull the battery release switch.
  4. Acer Aspire E1-470P-6659 Motherboard Replacement: paso 4, imagen 1 de 3 Acer Aspire E1-470P-6659 Motherboard Replacement: paso 4, imagen 2 de 3 Acer Aspire E1-470P-6659 Motherboard Replacement: paso 4, imagen 3 de 3
    • Remove the battery from the laptop.
  5. Acer Aspire E1-470P-6659 Motherboard Replacement, Hard Drive: paso 5, imagen 1 de 2 Acer Aspire E1-470P-6659 Motherboard Replacement, Hard Drive: paso 5, imagen 2 de 2
    • Remove nineteen screws from the back panel using a Phillips #0 Screwdriver .
  6. Acer Aspire E1-470P-6659 Motherboard Replacement: paso 6, imagen 1 de 3 Acer Aspire E1-470P-6659 Motherboard Replacement: paso 6, imagen 2 de 3 Acer Aspire E1-470P-6659 Motherboard Replacement: paso 6, imagen 3 de 3
    • Run the plastic opening tool across from one corner to another along the edge.
    • Separate the keyboard panel gently.
    • Lift the keyboard slowly from the laptop but do not lift completely because there are ribbon cables attached.
  7. Acer Aspire E1-470P-6659 Motherboard Replacement: paso 7, imagen 1 de 2 Acer Aspire E1-470P-6659 Motherboard Replacement: paso 7, imagen 2 de 2
    • Disconnect the two keyboard assembly ribbon cables from motherboard.
    • To release small ribbon cable, use spudger or fingers to flip gray bar along edge over.
    • To release larger ribbon cable, use pry tool or spudger to slide white plastic clip forward.
  8. Acer Aspire E1-470P-6659 Motherboard Replacement: paso 8, imagen 1 de 1
    • Pull up the release tab beside the hard drive.
    • Disconnect portion of ribbon cable that is covering the hard drive.
    • Handle the ribbon carefully. Do not break the metal contact.
    • While reconnecting the ribbon after replacing a new hard drive, face the blue side with a label up. Make sure the black line beside the sticker is not crooked, so that the ribbon is tight.
  9. Acer Aspire E1-470P-6659 Motherboard Replacement: paso 9, imagen 1 de 1
    • Remove the hard drive screw using Phillips #0 Screwdriver.
  10. Acer Aspire E1-470P-6659 Motherboard Replacement: paso 10, imagen 1 de 1
    • Pull the hard drive out gently. Be aware that it is connected to the adapter.
    • Gently remove adapter by pulling on both ends simultaneously to separate it from the hard drive.
  11. Acer Aspire E1-470P-6659 Motherboard Replacement, Motherboard: paso 11, imagen 1 de 3 Acer Aspire E1-470P-6659 Motherboard Replacement, Motherboard: paso 11, imagen 2 de 3 Acer Aspire E1-470P-6659 Motherboard Replacement, Motherboard: paso 11, imagen 3 de 3
    • Remove additional screws that can be found on the motherboard.
    • Remove the green wifi card from motherboard.
    • Use spudger to disconnect the fan and motherboard from laptop.
  12. Acer Aspire E1-470P-6659 Motherboard Replacement: paso 12, imagen 1 de 2 Acer Aspire E1-470P-6659 Motherboard Replacement: paso 12, imagen 2 de 2
    • Remove the cable attached to motherboard.
    • Gently lift and remove the motherboard from the laptop.
Conclusión
Faith Lobaton
Miembro Desde 10/22/18
497 Reputación
3 Guías creadas
Equipo
UC Davis, Team S4-G5, Lore Fall 2018 Miembro de UC Davis, Team S4-G5, Lore Fall 2018
UCD-LORE-F18S4G5
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 6
Ultimos 30 días: 21
Todo El Tiempo: 925
