Introducción
If you have problems with the laptop heating up, or the cooling fans need to be replaced or repaired, use this guide to remove and replace your laptop’s cooling fans.
Qué necesitas
Remove nineteen screws from the back panel using a Phillips #0 Screwdriver .
Remove additional screws that can be found on the motherboard.
Remove the green wifi card from motherboard.
Use spudger to disconnect the fan and motherboard from laptop.
Flip the motherboard and fan piece over.
Remove the four screws using the Phillips #000 Screwdriver.
