Introducción
This guide will walk you through the process of replacing the motherboard on an Acer Aspire E 11.
Qué necesitas
Unscrew the thirteen 6.2mm Phillips #1 screws located on the bottom of the device.
Press and hold the small black button located on the motherboard just above the battery for five seconds.
Locate the keyboard cable on the motherboard. Using, two plastic opening tools on each side of the connector, pull the two gray tabs outward and then remove the cable from the motherboard.
3 personas más completaron esta guía.
3 comentarios
Some of the bullet points can be broken up into information points or divided into more bullet points per step. Also, make sure the exposure is high enough to make all parts visible
Me podrían decir cual es el modelo de la pila del BIOS de este modelo e11 , por favor
