Saltar al contenido principal
Acer Aspire E 11 Battery Replacement
Qué necesitas
  1. Acer Aspire E 11 Battery Replacement, Lower Case: paso 1, imagen 1 de 2 Acer Aspire E 11 Battery Replacement, Lower Case: paso 1, imagen 2 de 2
    • Unscrew the thirteen 6.2mm Phillips #1 screws located on the bottom of the device.
  2. Acer Aspire E 11 Battery Replacement: paso 2, imagen 1 de 3 Acer Aspire E 11 Battery Replacement: paso 2, imagen 2 de 3 Acer Aspire E 11 Battery Replacement: paso 2, imagen 3 de 3
    • Lift the back panel using a plastic opening tool. Slowly make your way around the device until the back panel comes off.
  3. Acer Aspire E 11 Battery Replacement, Battery: paso 3, imagen 1 de 2 Acer Aspire E 11 Battery Replacement, Battery: paso 3, imagen 2 de 2
    • Press and hold the small black button located on the motherboard just above the battery for five seconds.
  4. Acer Aspire E 11 Battery Replacement: paso 4, imagen 1 de 3 Acer Aspire E 11 Battery Replacement: paso 4, imagen 2 de 3 Acer Aspire E 11 Battery Replacement: paso 4, imagen 3 de 3
    • Using two plastic opening tools tightly grab the connector going from the battery to the motherboard and pull to unplug.
  5. Acer Aspire E 11 Battery Replacement: paso 5, imagen 1 de 3 Acer Aspire E 11 Battery Replacement: paso 5, imagen 2 de 3 Acer Aspire E 11 Battery Replacement: paso 5, imagen 3 de 3
    • Unscrew two 6.2 mm Phillips #1 screws on the right and left sides of the battery.
  6. Acer Aspire E 11 Battery Replacement: paso 6, imagen 1 de 1
    • Carefully remove the battery by lifting it out of the casing.
Conclusión
9 personas más completaron esta guía.
Equipo
USF Tampa, Team 16-1, Blackwell Winter 2016 Miembro de USF Tampa, Team 16-1, Blackwell Winter 2016
USFT-BLACKWELL-W16S16G1
4 Miembros
11 Guías creadas
5 comentarios
Excellent instructions, very precise and easy to follow. Great job!!!!
[deleted] - Contestar
Can I remove the battery and use only the ac adapter to power it? Will it work and not cause damage to the unit?
json_viray - Contestar
when you take the battery out it works ok and when you put the battery the orange light when take out the battery its fine could it be the battery or board connector
steve varney - Contestar
when battery is out it works fine when connect out and orange and blue light come on then no display remove battery every returns to normal
Thanks - battery replacement carried out successfully by a technical incompetent! This step-by-step guide is much clearer and easier to follow than a video - wish there were more like this out there.
willstac1 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 27
Todo El Tiempo: 10,900
