Saltar al contenido principal
Acer Aspire 8735G Battery Replacement
Qué necesitas
  1. Acer Aspire 8735G Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Before proceeding, power down your Laptop and remove the power cable.
    • Close the display and lay it on a flat surface, top-side down.
  2. Acer Aspire 8735G Battery Replacement: paso 2, imagen 1 de 1
    • Unlock the battery by sliding the battery lock to the unlock part.
  3. Acer Aspire 8735G Battery Replacement: paso 3, imagen 1 de 1
    • Slide the middle lock to the right and the battery will pop up.
  4. Acer Aspire 8735G Battery Replacement: paso 4, imagen 1 de 1
    • If you want to replace the battery and nothing else then now is the time to do so.
    • Once the battery hatch is unlocked you can now safely remove the battery.
Conclusión
Regome
Miembro Desde 01/20/23
767 Reputación
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 79
