Saltar al contenido principal
Acer Aspire 774G-58GS Thermal Paste Replacement
Qué necesitas
  1. Acer Aspire 774G-58GS Thermal Paste Replacement, Thermal Paste: paso 1, imagen 1 de 3 Acer Aspire 774G-58GS Thermal Paste Replacement, Thermal Paste: paso 1, imagen 2 de 3 Acer Aspire 774G-58GS Thermal Paste Replacement, Thermal Paste: paso 1, imagen 3 de 3
    • Remove the three screws from the plate that covers the RAM and HDD using a Phillips #0 screwdriver.
    • Remove the plate from the laptop.
  2. Acer Aspire 774G-58GS Thermal Paste Replacement: paso 2, imagen 1 de 2 Acer Aspire 774G-58GS Thermal Paste Replacement: paso 2, imagen 2 de 2
    • Remove the DVD drive and the three screws that are underneath it.
    • Remove all the screws surrounding the backplate.
  3. Acer Aspire 774G-58GS Thermal Paste Replacement: paso 3, imagen 1 de 3 Acer Aspire 774G-58GS Thermal Paste Replacement: paso 3, imagen 2 de 3 Acer Aspire 774G-58GS Thermal Paste Replacement: paso 3, imagen 3 de 3
    • Disconnect the speaker wire beneath the RAM.
    • Gently remove the backplate from the laptop.
  4. Acer Aspire 774G-58GS Thermal Paste Replacement: paso 4, imagen 1 de 2 Acer Aspire 774G-58GS Thermal Paste Replacement: paso 4, imagen 2 de 2
    • Remove the five screws from the heat sink.
    • Take a cotton ball and dab it with isopropyl alcohol.
    • Use the cotton ball to wipe the old thermal paste from the heat sink.
  5. Acer Aspire 774G-58GS Thermal Paste Replacement: paso 5, imagen 1 de 3 Acer Aspire 774G-58GS Thermal Paste Replacement: paso 5, imagen 2 de 3 Acer Aspire 774G-58GS Thermal Paste Replacement: paso 5, imagen 3 de 3
    • Take another cotton ball, dab it with isopropyl alcohol, and gently wipe the thermal paste off of the GPU and CPU.
    • There is no need to rub hard as it should come off with ease.
    • Once the thermal paste is completely off, let the heat sink dry for a couple of minutes.
    • Apply a dab of new thermal paste in the middle of the CPU and GPU.
    • Corsair TM30 thermal paste is used in this guide.
  6. Acer Aspire 774G-58GS Thermal Paste Replacement: paso 6, imagen 1 de 1
    • Put the heatsink back on and screw it in place.
Conclusión
Abdul Munam Khan
Miembro Desde 01/13/22
133 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 9
Ultimos 30 días: 27
Todo El Tiempo: 645
