Saltar al contenido principal
Acer Aspire 7741Z-4643 Wireless Card Replacement
Qué necesitas
  1. Acer Aspire 7741Z-4643 Wireless Card Replacement, Wireless Card: paso 1, imagen 1 de 2 Acer Aspire 7741Z-4643 Wireless Card Replacement, Wireless Card: paso 1, imagen 2 de 2
    • Begin by unscrewing the four phillips #0 7.5mm screws on the plate on the underside. Remove the plate by lifting up.
  2. Acer Aspire 7741Z-4643 Wireless Card Replacement: paso 2, imagen 1 de 3 Acer Aspire 7741Z-4643 Wireless Card Replacement: paso 2, imagen 2 de 3 Acer Aspire 7741Z-4643 Wireless Card Replacement: paso 2, imagen 3 de 3
    • Unscrew the one phillips #0 4.0mm screw at the top of the card in order for it to be removed.
    • After the screw is removed, slide the card out. Remove connections to the terminals by pulling up on the connection carefully.
Conclusión
Philip Matena
Miembro Desde 10/23/18
95 Reputación
1 Guía escrita
Equipo
UC Davis, Team S11-G4, Lore Fall 2018 Miembro de UC Davis, Team S11-G4, Lore Fall 2018
UCD-LORE-F18S11G4
4 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 475
