Introducción
Is your computer not loading properly? Consider using this guide to replace the RAM in your device.
Qué necesitas
Begin with the bottom of the laptop facing up.
With a screwdriver, unscrew the four phillips #0 7.5mm screw around the bottom panel.
Lift the panel at the top and pull towards you to remove it from the laptop.
Casi Terminas!
Conclusión
