Saltar al contenido principal
Acer Aspire 7736Z-4809 RAM Replacement
Qué necesitas
  1. Acer Aspire 7736Z-4809 RAM Replacement, Back Panel: paso 1, imagen 1 de 2 Acer Aspire 7736Z-4809 RAM Replacement, Back Panel: paso 1, imagen 2 de 2
    • Use the Phillips #1 screwdriver to remove the eight 6.5 mm Phillips #1 screws.
    • Only the four screws in the center are removable, the four along the edges are held in by rivets but can be loosened.
  2. Acer Aspire 7736Z-4809 RAM Replacement: paso 2, imagen 1 de 3 Acer Aspire 7736Z-4809 RAM Replacement: paso 2, imagen 2 de 3 Acer Aspire 7736Z-4809 RAM Replacement: paso 2, imagen 3 de 3
    • Remove the back panel of the laptop.
  3. Acer Aspire 7736Z-4809 RAM Replacement: paso 3, imagen 1 de 1
    • Connect a grounding cord to a metal interface on the laptop.
    • Ground the laptop to prevent static electricity from damaging the electrical components inside the laptop.
  4. Acer Aspire 7736Z-4809 RAM Replacement, RAM: paso 4, imagen 1 de 3 Acer Aspire 7736Z-4809 RAM Replacement, RAM: paso 4, imagen 2 de 3 Acer Aspire 7736Z-4809 RAM Replacement, RAM: paso 4, imagen 3 de 3
    • Release the tabs on the RAM by bending the tabs away from the RAM.
    • The RAM will rise upwards at an angle.
  5. Acer Aspire 7736Z-4809 RAM Replacement: paso 5, imagen 1 de 2 Acer Aspire 7736Z-4809 RAM Replacement: paso 5, imagen 2 de 2
    • Pull the RAM out of the slot.
    • If you are replacing both sticks of RAM, repeat the previous step for removing the RAM.
Conclusión
Equipo
UC Davis, Team 2-4, Oliver Fall 2016 Miembro de UC Davis, Team 2-4, Oliver Fall 2016
UCD-OLIVER-F16S2G4
5 Miembros
10 Guías creadas
2 comentarios
“supports the DDR2 667MHz memory,240-pin soDIMM RAM “
It’s a laptop and what you are holding is a 200-pin soDIMM RAM module.
BaronDRS - Contestar
Not only is it 200-pin soDIMM module instead of a 240-pin soDIMM module, it's a pc2-6400 (800MHz) and not a pc2-5300 (667MHz).
1videopirate - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 8
Todo El Tiempo: 673
