Saltar al contenido principal
Acer Aspire 7736Z-4809 Hard Drive Replacement
Qué necesitas
  1. Acer Aspire 7736Z-4809 Hard Drive Replacement, Acer Aspire 7736Z-4809 Repair Preparation: paso 1, imagen 1 de 1
    • Unplug and power off the laptop.
    • If the battery is still connected to the laptop, remove the battery.
  2. Acer Aspire 7736Z-4809 Hard Drive Replacement: paso 2, imagen 1 de 1
    • Flip over the laptop so that the back panel of the laptop is facing up.
  3. Acer Aspire 7736Z-4809 Hard Drive Replacement, Back Panel: paso 3, imagen 1 de 2 Acer Aspire 7736Z-4809 Hard Drive Replacement, Back Panel: paso 3, imagen 2 de 2
    • Use the Phillips #1 screwdriver to remove the eight 6.5 mm Phillips #1 screws.
    • Only the four screws in the center are removable, the four along the edges are held in by rivets but can be loosened.
  4. Acer Aspire 7736Z-4809 Hard Drive Replacement: paso 4, imagen 1 de 3 Acer Aspire 7736Z-4809 Hard Drive Replacement: paso 4, imagen 2 de 3 Acer Aspire 7736Z-4809 Hard Drive Replacement: paso 4, imagen 3 de 3
    • Remove the back panel of the laptop.
  5. Acer Aspire 7736Z-4809 Hard Drive Replacement: paso 5, imagen 1 de 1
    • Connect a grounding cord to a metal interface on the laptop.
    • Ground the laptop to prevent static electricity from damaging the electrical components inside the laptop.
  6. Acer Aspire 7736Z-4809 Hard Drive Replacement, Hard Drive: paso 6, imagen 1 de 2 Acer Aspire 7736Z-4809 Hard Drive Replacement, Hard Drive: paso 6, imagen 2 de 2
    • Use the Phillips #1 screwdriver to remove the 3.5mm Phillips #1 screw.
  7. Acer Aspire 7736Z-4809 Hard Drive Replacement: paso 7, imagen 1 de 2 Acer Aspire 7736Z-4809 Hard Drive Replacement: paso 7, imagen 2 de 2
    • Slide the bracket towards you to release it from the frame.
  8. Acer Aspire 7736Z-4809 Hard Drive Replacement: paso 8, imagen 1 de 3 Acer Aspire 7736Z-4809 Hard Drive Replacement: paso 8, imagen 2 de 3 Acer Aspire 7736Z-4809 Hard Drive Replacement: paso 8, imagen 3 de 3
    • Use the black tab to pull the hard drive up and out of the laptop.
  9. Acer Aspire 7736Z-4809 Hard Drive Replacement: paso 9, imagen 1 de 2 Acer Aspire 7736Z-4809 Hard Drive Replacement: paso 9, imagen 2 de 2
    • Use the Phillips #1 screwdriver to remove the four 3.5 Phillips #1 screws.
  10. Acer Aspire 7736Z-4809 Hard Drive Replacement: paso 10, imagen 1 de 1
    • Remove the hard drive from the bracket and install the new hard drive.
Conclusión
Una persona más ha completado esta guía.
Equipo
UC Davis, Team 2-4, Oliver Fall 2016 Miembro de UC Davis, Team 2-4, Oliver Fall 2016
UCD-OLIVER-F16S2G4
5 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 5
Todo El Tiempo: 1,088
