Saltar al contenido principal
Acer Aspire 7736Z-4809 CPU Fan Replacement
Qué necesitas
  1. Acer Aspire 7736Z-4809 CPU Fan Replacement, Acer Aspire 7736Z-4809 Repair Preparation: paso 1, imagen 1 de 1
    • Unplug and power off the laptop.
    • If the battery is still connected to the laptop, remove the battery.
  2. Acer Aspire 7736Z-4809 CPU Fan Replacement: paso 2, imagen 1 de 1
    • Flip over the laptop so that the back panel of the laptop is facing up.
  3. Acer Aspire 7736Z-4809 CPU Fan Replacement, Back Panel: paso 3, imagen 1 de 2 Acer Aspire 7736Z-4809 CPU Fan Replacement, Back Panel: paso 3, imagen 2 de 2
    • Use the Phillips #1 screwdriver to remove the eight 6.5 mm Phillips #1 screws.
    • Only the four screws in the center are removable, the four along the edges are held in by rivets but can be loosened.
  4. Acer Aspire 7736Z-4809 CPU Fan Replacement: paso 4, imagen 1 de 3 Acer Aspire 7736Z-4809 CPU Fan Replacement: paso 4, imagen 2 de 3 Acer Aspire 7736Z-4809 CPU Fan Replacement: paso 4, imagen 3 de 3
    • Remove the back panel of the laptop.
  5. Acer Aspire 7736Z-4809 CPU Fan Replacement: paso 5, imagen 1 de 1
    • Connect a grounding cord to a metal interface on the laptop.
    • Ground the laptop to prevent static electricity from damaging the electrical components inside the laptop.
  6. Acer Aspire 7736Z-4809 CPU Fan Replacement, CPU Fan: paso 6, imagen 1 de 3 Acer Aspire 7736Z-4809 CPU Fan Replacement, CPU Fan: paso 6, imagen 2 de 3 Acer Aspire 7736Z-4809 CPU Fan Replacement, CPU Fan: paso 6, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Use tweezers to remove the fan cable from its slot.
    • The cables consist of red, black, and yellow wires.
  7. Acer Aspire 7736Z-4809 CPU Fan Replacement: paso 7, imagen 1 de 2 Acer Aspire 7736Z-4809 CPU Fan Replacement: paso 7, imagen 2 de 2
    • Use the Phillips #1 screwdriver to unscrew the four Phillips #1 screws that connect the cooling fan from the panel.
    • These screws are held in the unit via springs. You cannot remove them. They can only be loosened.
  8. Acer Aspire 7736Z-4809 CPU Fan Replacement: paso 8, imagen 1 de 3 Acer Aspire 7736Z-4809 CPU Fan Replacement: paso 8, imagen 2 de 3 Acer Aspire 7736Z-4809 CPU Fan Replacement: paso 8, imagen 3 de 3
    • Carefully remove the cooling fan from the motherboard.
    • Slightly lift up the fan, gradually slide it towards you and then fully remove it from the case.
  9. Acer Aspire 7736Z-4809 CPU Fan Replacement: paso 9, imagen 1 de 1
    • Install the modified or new cooling fan.
Conclusión
2 personas más completaron esta guía.
Equipo
UC Davis, Team 2-4, Oliver Fall 2016 Miembro de UC Davis, Team 2-4, Oliver Fall 2016
UCD-OLIVER-F16S2G4
5 Miembros
10 Guías creadas
Un comentario
You’ll need some thermal compound when reinstalling for the heat syncs under the copper tube.
Minks - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 11
Todo El Tiempo: 791
