Saltar al contenido principal
Acer Aspire 7736Z-4809 Back Panel Removal
Qué necesitas
  1. Acer Aspire 7736Z-4809 Back Panel Removal, Acer Aspire 7736Z-4809 Repair Preparation: paso 1, imagen 1 de 1
    • Unplug and power off the laptop.
    • If the battery is still connected to the laptop, remove the battery.
  2. Acer Aspire 7736Z-4809 Back Panel Removal: paso 2, imagen 1 de 1
    • Flip over the laptop so that the back panel of the laptop is facing up.
  3. Acer Aspire 7736Z-4809 Back Panel Removal, Back Panel: paso 3, imagen 1 de 2 Acer Aspire 7736Z-4809 Back Panel Removal, Back Panel: paso 3, imagen 2 de 2
    • Use the Phillips #1 screwdriver to remove the eight 6.5 mm Phillips #1 screws.
    • Only the four screws in the center are removable, the four along the edges are held in by rivets but can be loosened.
  4. Acer Aspire 7736Z-4809 Back Panel Removal: paso 4, imagen 1 de 3 Acer Aspire 7736Z-4809 Back Panel Removal: paso 4, imagen 2 de 3 Acer Aspire 7736Z-4809 Back Panel Removal: paso 4, imagen 3 de 3
    • Remove the back panel of the laptop.
  5. Acer Aspire 7736Z-4809 Back Panel Removal: paso 5, imagen 1 de 1
    • Connect a grounding cord to a metal interface on the laptop.
    • Ground the laptop to prevent static electricity from damaging the electrical components inside the laptop.
Conclusión
Equipo
UC Davis, Team 2-4, Oliver Fall 2016 Miembro de UC Davis, Team 2-4, Oliver Fall 2016
UCD-OLIVER-F16S2G4
Miembros de 5
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 18
Ultimos 30 días: 20
Todo El Tiempo: 609
