Saltar al contenido principal
Acer Aspire 6530-6522 Secondary Hard Drive Replacement
Qué necesitas
  1. Acer Aspire 6530-6522 Secondary Hard Drive Replacement, Battery: paso 1, imagen 1 de 2 Acer Aspire 6530-6522 Secondary Hard Drive Replacement, Battery: paso 1, imagen 2 de 2
    • Make sure the device is unplugged and completely powered down.
    • Turn the device over.
  2. Acer Aspire 6530-6522 Secondary Hard Drive Replacement: paso 2, imagen 1 de 2 Acer Aspire 6530-6522 Secondary Hard Drive Replacement: paso 2, imagen 2 de 2
    • The lock switch can slide either towards or away from the battery. If it is pushed towards the battery, the release switch is locked and the battery can not be released.
    • Slide the switch away from the battery.
  3. Acer Aspire 6530-6522 Secondary Hard Drive Replacement: paso 3, imagen 1 de 3 Acer Aspire 6530-6522 Secondary Hard Drive Replacement: paso 3, imagen 2 de 3 Acer Aspire 6530-6522 Secondary Hard Drive Replacement: paso 3, imagen 3 de 3
    • The battery release switch is just to the inside of the battery and slides parallel to it.
    • Push the switch to the side. It is not just an open or close switch, it actually pops the battery up so you will feel some resistance.
    • When inserting a battery back into the device, you do not need to touch this switch. Just press the battery firmly down, you will see and hear this switch catch.
  4. Acer Aspire 6530-6522 Secondary Hard Drive Replacement: paso 4, imagen 1 de 3 Acer Aspire 6530-6522 Secondary Hard Drive Replacement: paso 4, imagen 2 de 3 Acer Aspire 6530-6522 Secondary Hard Drive Replacement: paso 4, imagen 3 de 3
    • Pull the battery up and out. Use a plastic opening tool if necessary.
  5. Acer Aspire 6530-6522 Secondary Hard Drive Replacement, Secondary Hard Drive: paso 5, imagen 1 de 2 Acer Aspire 6530-6522 Secondary Hard Drive Replacement, Secondary Hard Drive: paso 5, imagen 2 de 2
    • While looking at the bottom of the device upside down from the front, the secondary hard drive is in the near, left corner.
    • Using a Phillips #1 screwdriver, remove the two 7mm screws on the right side of the cover.
  6. Acer Aspire 6530-6522 Secondary Hard Drive Replacement: paso 6, imagen 1 de 1
    • Using a Phillips #1 screwdriver, remove the two 3mm screws near the front of the device.
    • Using the plastic pull tab to pull the drive to the left, away from the connections.
    • Lift the drive up and out of the device.
  7. Acer Aspire 6530-6522 Secondary Hard Drive Replacement: paso 7, imagen 1 de 3 Acer Aspire 6530-6522 Secondary Hard Drive Replacement: paso 7, imagen 2 de 3 Acer Aspire 6530-6522 Secondary Hard Drive Replacement: paso 7, imagen 3 de 3
    • Using the Phillips #1 screwdriver, remove the four 3.5mm screws at the corners of the cover.
    • Lift the cover off the hard drive.
Conclusión
Una persona más ha completado esta guía.
William Michaud
Miembro Desde 03/20/18
343 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 263
