Saltar al contenido principal
Acer Aspire 6530-6522 Power Board Replacement
Qué necesitas
  1. Acer Aspire 6530-6522 Power Board Replacement, Battery: paso 1, imagen 1 de 2 Acer Aspire 6530-6522 Power Board Replacement, Battery: paso 1, imagen 2 de 2
    • Make sure the device is unplugged and completely powered down.
    • Turn the device over.
  2. Acer Aspire 6530-6522 Power Board Replacement: paso 2, imagen 1 de 2 Acer Aspire 6530-6522 Power Board Replacement: paso 2, imagen 2 de 2
    • The lock switch can slide either towards or away from the battery. If it is pushed towards the battery, the release switch is locked and the battery can not be released.
    • Slide the switch away from the battery.
  3. Acer Aspire 6530-6522 Power Board Replacement: paso 3, imagen 1 de 3 Acer Aspire 6530-6522 Power Board Replacement: paso 3, imagen 2 de 3 Acer Aspire 6530-6522 Power Board Replacement: paso 3, imagen 3 de 3
    • The battery release switch is just to the inside of the battery and slides parallel to it.
    • Push the switch to the side. It is not just an open or close switch, it actually pops the battery up so you will feel some resistance.
    • When inserting a battery back into the device, you do not need to touch this switch. Just press the battery firmly down, you will see and hear this switch catch.
  4. Acer Aspire 6530-6522 Power Board Replacement: paso 4, imagen 1 de 3 Acer Aspire 6530-6522 Power Board Replacement: paso 4, imagen 2 de 3 Acer Aspire 6530-6522 Power Board Replacement: paso 4, imagen 3 de 3
    • Pull the battery up and out. Use a plastic opening tool if necessary.
  5. Acer Aspire 6530-6522 Power Board Replacement, Power Board: paso 5, imagen 1 de 2 Acer Aspire 6530-6522 Power Board Replacement, Power Board: paso 5, imagen 2 de 2
    • Using the Phillips #1 screwdriver, remove the ten 7mm screws in the bottom of the device that are holding the top panel.
    • Turn the device over and open it.
  6. Acer Aspire 6530-6522 Power Board Replacement: paso 6, imagen 1 de 2 Acer Aspire 6530-6522 Power Board Replacement: paso 6, imagen 2 de 2
    • Lift the top panel up from the back, turning it over forward.
  7. Acer Aspire 6530-6522 Power Board Replacement: paso 7, imagen 1 de 1
    • Lift the latch locking the cable.
    • Pull the cable free.
  8. Acer Aspire 6530-6522 Power Board Replacement: paso 8, imagen 1 de 2 Acer Aspire 6530-6522 Power Board Replacement: paso 8, imagen 2 de 2
    • Pull the cable towards you to unplug it. Use tweezers if necessary.
  9. Acer Aspire 6530-6522 Power Board Replacement: paso 9, imagen 1 de 2 Acer Aspire 6530-6522 Power Board Replacement: paso 9, imagen 2 de 2
    • Using the Phillips #1 screwdriver, remove the three 3mm screws from the power board.
    • Lift power board to remove it.
Conclusión
William Michaud
Miembro Desde 03/20/18
343 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 5
Ultimos 30 días: 9
Todo El Tiempo: 258
