Introducción
This guide will show you how to remove the hard drive. You will need to do this if your hard drive is damaged or faulty and you have a new one, or if you are upgrading to larger one.
Qué necesitas
Make sure the device is unplugged and completely powered down.
Turn the device over.
Using the Phillips #1 screwdriver remove the nine 7mm screws in the bottom panel.
Lift and remove the panel.
Una persona más ha completado esta guía.
