Introducción
The goal of this guide is to help replace the motherboard in your Acer Aspire 5750-6677. The motherboard is an essential component to any computer. The computer’s motherboard provides a platform for communication between the central processing unit (CPU) and memory, as well as providing connection points for any additional input and/or output components. Replacing the motherboard is considered to be difficult and will require approximately 1 hour to complete and the only tool you will need is a Phillips #0 screwdriver.
Qué necesitas
Flip the device over so the backside is facing up.
Remove the two screws with the Phillips #0 screwdriver.
Start by flipping the device over to expose the screws.
Remove ten screws with the Phillips #0 screwdriver.
2 personas más completaron esta guía.
