Saltar al contenido principal
Acer Aspire 5750-6667 Optical Drive Replacement
Qué necesitas
  1. Acer Aspire 5750-6667 Optical Drive Replacement, Battery: paso 1, imagen 1 de 2 Acer Aspire 5750-6667 Optical Drive Replacement, Battery: paso 1, imagen 2 de 2
    • Unplug the charging cable from the laptop and the wall. Failure to disconnect the charging cable could result in electric shock.
    • Turn the laptop over.
    • Locate the orange switch next to the battery.
  2. Acer Aspire 5750-6667 Optical Drive Replacement: paso 2, imagen 1 de 3 Acer Aspire 5750-6667 Optical Drive Replacement: paso 2, imagen 2 de 3 Acer Aspire 5750-6667 Optical Drive Replacement: paso 2, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Using a small tool such as tweezers or a pen, slide the orange switch completely to the left to unlock the battery.
    • While holding the orange switch in place, lift the battery by the lip and pull it away from the laptop.
  3. Acer Aspire 5750-6667 Optical Drive Replacement, Optical Drive: paso 3, imagen 1 de 2 Acer Aspire 5750-6667 Optical Drive Replacement, Optical Drive: paso 3, imagen 2 de 2
    • Locate the black screw just above the battery.
    • Remove the black screw holding the optical drive in place by using a Phillips #0 screwdriver.
  4. Acer Aspire 5750-6667 Optical Drive Replacement: paso 4, imagen 1 de 2 Acer Aspire 5750-6667 Optical Drive Replacement: paso 4, imagen 2 de 2
    • Pull the optical drive free from the laptop.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 11
Todo El Tiempo: 1,248
