Introducción
RAM in a laptop is often upgraded in order to make increase storage capacity and performance. RAM is easily replaced by removing 2 screws and pulling on two clamps that surround the RAM.
Qué necesitas
Flip the laptop over and locate the bottom access panel. It is opposite the battery.
Locate the 2 screws that hold the panel in place and unscrew them using a Phillips PH0 screwdriver.
Lift the clear plastic flap and locate the pair of metal brackets that are holding the top RAM in place.
Using your thumbs, push the brackets away from the RAM . It should pop up when released.
You can now gently pull the top RAM out of the laptop.
2 personas más completaron esta guía.
