Introducción
Does your laptop fan make noise even after cleaning?
Here's how simple it is to change.
Partes
No se requieren partes.
  1. Retrieve all Screw's from the bottom of the laptop and organize them into 2 different sets. When removing the back cover gently press on audio connections on the back right of the laptop. When removing the back cover gently press on audio connections on the back right of the laptop.
    • Retrieve all Screw's from the bottom of the laptop and organize them into 2 different sets.
    • When removing the back cover gently press on audio connections on the back right of the laptop.
  2. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  3. Carefully release and unplug every wire that connects to the fan. Carefully release and unplug every wire that connects to the fan. Carefully release and unplug every wire that connects to the fan.
    • Carefully release and unplug every wire that connects to the fan.
  4. Release the screw that connects the fan to the base of the laptop. Carefully remove your fan and heat sink. Apply heat paste to the center before replacing the fan and heat sink. Then reinsert the screw and plugs. Apply heat paste to the center before replacing the fan and heat sink. Then reinsert the screw and plugs.
    • Release the screw that connects the fan to the base of the laptop. Carefully remove your fan and heat sink.
    • Apply heat paste to the center before replacing the fan and heat sink. Then reinsert the screw and plugs.
Conclusión
7 personas más completaron esta guía.
JeanChristophe
Miembro Desde 19/11/10
259 Reputación
1 Guía escrita
May need to expand the "apply heat paste to center" section. Need to remove old paste first, etc. etc. A good bird's eye view intro, though
polishtext4 - Contestar
Tanks you…
I'll look forward for adding this info.
JeanChristophe -
Seemed like I was going to rip the motherboard up where the usb ports are by the audio connector, why isn't the %#*@ thing screwed down? Lol If I push down by the audio connector like you mention and pull it up from the other side will ot be fine, felt and looked like I might snap the board.
Clayton Boyle - Contestar
Good job, did have to Emphasis about releasing the audio connectors
Thaine Ferris - Contestar
I didn't know how to explain better…
Some trick of trade?
JeanChristophe -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 2
Últimos 7 Días: 6
Últimos 30 Días: 26
Todo El Tiempo: 5,729
