Saltar al contenido principal
Acer Aspire 5742G Memory stick Replacement
Qué necesitas
Resumen del Video
click here for video
  1. Acer Aspire 5742G Memory stick Replacement, Memory stick: paso 1, imagen 1 de 1
    • Make sure your computer is off and remove the battery with the security tabs shown in the picture
  2. Acer Aspire 5742G Memory stick Replacement: paso 2, imagen 1 de 1
    • Remove these philips screws, only two :)
  3. Acer Aspire 5742G Memory stick Replacement: paso 3, imagen 1 de 2 Acer Aspire 5742G Memory stick Replacement: paso 3, imagen 2 de 2
    • Then from the dented tab, either your finger, card or spudger will work, and start prying GENTLY!
    • Easily work your way around.
    • WARNING! PLASTIC TABS! be careful not to break them!
  4. Acer Aspire 5742G Memory stick Replacement: paso 4, imagen 1 de 1
    • Now you've removed the cover, you will get access to your Antenna, HDD, and RAM
    • Please remove both tabs with the memory stick at the same time
  5. Acer Aspire 5742G Memory stick Replacement: paso 5, imagen 1 de 1
    • Now put the new memory stick in!
    • When it is in, then gently push it downwards to lock it in place!
    • Be aware you have to line up the stick with a pin in the socket!!
Conclusión
2 personas más completaron esta guía.
Petter Berget
Miembro Desde 05/12/15
767 Reputación
3 Guías creadas
Equipo
Kid fixers Miembro de Kid fixers
Community
184 Miembros
256 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 4
Todo El Tiempo: 856
