Introducción
Removal of the hard drive is easy, but just be careful not to knock, jerk or drop it in the process as it's a delicate electromechanical device.
Partes
No se requieren partes.
  1. Move the battery catch to the "unlocked" position.
    • Move the battery catch to the "unlocked" position.
    • Pull back the second spring-loaded battery catch until the battery pops up.
    • Remove the battery.
  2. Turn the notebook around to face you.
    • Turn the notebook around to face you.
    • There are two Phillips #00 screws securing the cover panel to the rest of the notebook. Remove these screws.
    • Use a spudger to release the panel from the plastic retaining clips keeping it in place.
    • Do not apply too much force, or you may break the clips.
    • Remove the panel and set it aside.
    • Unscrew the Phillips #00 screw which retains the hard drive in place.
    • Gently slide the hard drive to the left in order to disengage the SATA connectors.
    • It may be quite stiff, in which case you can ease the hard drive out of the SATA connectors by inserting a spudger between the hard drive and the connector block.
    • Lift the drive out of the notebook.
Conclusión
14 personas más completaron esta guía.
Skylar MacDonald
Miembro Desde 04/12/11
1,696 Reputación
5 Guías creadas
Great guide except for the missing screw sizes. Does anybody know the screw sizes?
patrickscott - Contestar
I have this laptop with a bad HDD, it was a Toshiba 640 GB , 5400 RPM drive.
I like to know if this laptop supports 7200 RPM drives
Also, does this laptop support an SSD drive ?
Shahzaan - Contestar
Yes, any 2.5in SATA HDD or SSD can be fitted in place of any other.
Philip Le Riche -
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 27
Últimos 30 Días: 126
Todo El Tiempo: 36,073
