Saltar al contenido principal
Acer Aspire 5742 Hard Drive Removal
Qué necesitas
  1. Acer Aspire 5742 Hard Drive Removal, Battery: paso 1, imagen 1 de 3 Acer Aspire 5742 Hard Drive Removal, Battery: paso 1, imagen 2 de 3 Acer Aspire 5742 Hard Drive Removal, Battery: paso 1, imagen 3 de 3
    • Move the battery catch to the "unlocked" position.
    • Pull back the second spring-loaded battery catch until the battery pops up.
    • Remove the battery.
  2. Acer Aspire 5742 Hard Drive Removal, Cover Panel: paso 2, imagen 1 de 3 Acer Aspire 5742 Hard Drive Removal, Cover Panel: paso 2, imagen 2 de 3 Acer Aspire 5742 Hard Drive Removal, Cover Panel: paso 2, imagen 3 de 3
    • Turn the notebook around to face you.
    • There are two Phillips #00 screws securing the cover panel to the rest of the notebook. Remove these screws.
  3. Acer Aspire 5742 Hard Drive Removal: paso 3, imagen 1 de 3 Acer Aspire 5742 Hard Drive Removal: paso 3, imagen 2 de 3 Acer Aspire 5742 Hard Drive Removal: paso 3, imagen 3 de 3
    • Use a spudger to release the panel from the plastic retaining clips keeping it in place.
    • Do not apply too much force, or you may break the clips.
    • Remove the panel and set it aside.
  4. Acer Aspire 5742 Hard Drive Removal, Hard drive: paso 4, imagen 1 de 3 Acer Aspire 5742 Hard Drive Removal, Hard drive: paso 4, imagen 2 de 3 Acer Aspire 5742 Hard Drive Removal, Hard drive: paso 4, imagen 3 de 3
    • Unscrew the Phillips #00 screw which retains the hard drive in place.
    • Gently slide the hard drive to the left in order to disengage the SATA connectors.
    • It may be quite stiff, in which case you can ease the hard drive out of the SATA connectors by inserting a spudger between the hard drive and the connector block.
    • Lift the drive out of the notebook.
Conclusión
16 personas más completaron esta guía.
Skylar MacDonald
Miembro Desde 12/04/11
1,964 Reputación
5 Guías creadas
4 comentarios
Great guide except for the missing screw sizes. Does anybody know the screw sizes?
patrickscott - Contestar
I have this laptop with a bad HDD, it was a Toshiba 640 GB , 5400 RPM drive.
I like to know if this laptop supports 7200 RPM drives
Also, does this laptop support an SSD drive ?
Shahzaan - Contestar
Yes, any 2.5in SATA HDD or SSD can be fitted in place of any other.
Philip Le Riche -
I love this guide! It's the best! Thank You!
Mark Wiens - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 15
Ultimos 30 días: 72
Todo El Tiempo: 45,296
