Saltar al contenido principal
Acer Aspire 5742 CMOS Battery Replacement
Qué necesitas
  1. Acer Aspire 5742 CMOS Battery Replacement, Battery: paso 1, imagen 1 de 3 Acer Aspire 5742 CMOS Battery Replacement, Battery: paso 1, imagen 2 de 3 Acer Aspire 5742 CMOS Battery Replacement, Battery: paso 1, imagen 3 de 3
    • Move the battery catch to the "unlocked" position.
    • Pull back the second spring-loaded battery catch until the battery pops up.
    • Remove the battery.
  2. Acer Aspire 5742 CMOS Battery Replacement, Cover Panel: paso 2, imagen 1 de 3 Acer Aspire 5742 CMOS Battery Replacement, Cover Panel: paso 2, imagen 2 de 3 Acer Aspire 5742 CMOS Battery Replacement, Cover Panel: paso 2, imagen 3 de 3
    • Turn the notebook around to face you.
    • There are two Phillips #00 screws securing the cover panel to the rest of the notebook. Remove these screws.
  3. Acer Aspire 5742 CMOS Battery Replacement: paso 3, imagen 1 de 3 Acer Aspire 5742 CMOS Battery Replacement: paso 3, imagen 2 de 3 Acer Aspire 5742 CMOS Battery Replacement: paso 3, imagen 3 de 3
    • Use a spudger to release the panel from the plastic retaining clips keeping it in place.
    • Do not apply too much force, or you may break the clips.
    • Remove the panel and set it aside.
  4. Acer Aspire 5742 CMOS Battery Replacement, CMOS Battery: paso 4, imagen 1 de 2 Acer Aspire 5742 CMOS Battery Replacement, CMOS Battery: paso 4, imagen 2 de 2
    • After removing the cover panel, you will see the hard drive, the RAM, and the CMOS battery.
    • The CMOS battery is the silver coin-like object in the center.
  5. Acer Aspire 5742 CMOS Battery Replacement: paso 5, imagen 1 de 3 Acer Aspire 5742 CMOS Battery Replacement: paso 5, imagen 2 de 3 Acer Aspire 5742 CMOS Battery Replacement: paso 5, imagen 3 de 3
    • Press the tip of the spudger underneath the CMOS battery with very slight force.
    • Press down on the opposite side of the battery while prying the battery upward with the spudger.
    • After the battery is mostly lifted from the slot, you may pull out the battery with your fingers.
Conclusión
8 personas más completaron esta guía.
Bill Murray
Miembro Desde 10/24/16
581 Reputación
2 Guías creadas
Equipo
UMass Dartmouth, Team 2-6, Isaacson Fall 2016 Miembro de UMass Dartmouth, Team 2-6, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G6
3 Miembros
8 Guías creadas
Un comentario
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 15
Ultimos 30 días: 115
Todo El Tiempo: 14,348
