Saltar al contenido principal
Acer Aspire 5741-5698 WIFI Chipset Replacement
Qué necesitas
  1. Acer Aspire 5741-5698 WIFI Chipset Replacement, WIFI Chipset: paso 1, imagen 1 de 3 Acer Aspire 5741-5698 WIFI Chipset Replacement, WIFI Chipset: paso 1, imagen 2 de 3 Acer Aspire 5741-5698 WIFI Chipset Replacement, WIFI Chipset: paso 1, imagen 3 de 3
    • Begin on the back side of your laptop, locate these two screws then remove them with the JIS #0 driver bit.
  2. Acer Aspire 5741-5698 WIFI Chipset Replacement: paso 2, imagen 1 de 2 Acer Aspire 5741-5698 WIFI Chipset Replacement: paso 2, imagen 2 de 2
    • Once screws are removed you can pry up the panel to reveal some of your computers components.
  3. Acer Aspire 5741-5698 WIFI Chipset Replacement: paso 3, imagen 1 de 1
    • Locate your computers WIFI chip; it will have black and white wires attached to it.
  4. Acer Aspire 5741-5698 WIFI Chipset Replacement: paso 4, imagen 1 de 3 Acer Aspire 5741-5698 WIFI Chipset Replacement: paso 4, imagen 2 de 3 Acer Aspire 5741-5698 WIFI Chipset Replacement: paso 4, imagen 3 de 3
    • Using your fingers or a spudger, remove the black and white cables from the chip, at the connector.
  5. Acer Aspire 5741-5698 WIFI Chipset Replacement: paso 5, imagen 1 de 2 Acer Aspire 5741-5698 WIFI Chipset Replacement: paso 5, imagen 2 de 2
    • Using the same JIS#0 screw driver remove the single small 1/4 inch long screw.
  6. Acer Aspire 5741-5698 WIFI Chipset Replacement: paso 6, imagen 1 de 3 Acer Aspire 5741-5698 WIFI Chipset Replacement: paso 6, imagen 2 de 3 Acer Aspire 5741-5698 WIFI Chipset Replacement: paso 6, imagen 3 de 3
    • Now that the chip is released just gently remove it from its connector seat.
Conclusión
Alex Imbery
Miembro Desde 01/24/19
133 Reputación
1 Guía escrita
Equipo
Cal Poly, Team S18-G6, White Winter 2019 Miembro de Cal Poly, Team S18-G6, White Winter 2019
CPSU-WHITE-W19S18G6
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 17
Todo El Tiempo: 609
