Saltar al contenido principal
Acer Aspire 5740-6378 Hard Drive Replacement
Qué necesitas
  1. Acer Aspire 5740-6378 Hard Drive Replacement, Battery: paso 1, imagen 1 de 1
    • Slide the locking switch into the unlocked position to ready the battery for removal.
  2. Acer Aspire 5740-6378 Hard Drive Replacement: paso 2, imagen 1 de 1
    • Slide the release latch until the battery pops out.
  3. Acer Aspire 5740-6378 Hard Drive Replacement: paso 3, imagen 1 de 1
    • Remove the battery now that it's been unsecured.
  4. Acer Aspire 5740-6378 Hard Drive Replacement, Hard Drive: paso 4, imagen 1 de 1
    • Flip over the device so the back is facing upward.
  5. Acer Aspire 5740-6378 Hard Drive Replacement: paso 5, imagen 1 de 2 Acer Aspire 5740-6378 Hard Drive Replacement: paso 5, imagen 2 de 2
    • Remove the five 8.7mm Phillips #0 screws securing the back panel.
  6. Acer Aspire 5740-6378 Hard Drive Replacement: paso 6, imagen 1 de 2 Acer Aspire 5740-6378 Hard Drive Replacement: paso 6, imagen 2 de 2
    • Remove the back panel using a spudger or other similar tool to lever it open to reveal the hard drive and other internal components.
  7. Acer Aspire 5740-6378 Hard Drive Replacement: paso 7, imagen 1 de 1
    • Remove the single 3mm Phillips #0 screw that is holding the hard drive in place.
  8. Acer Aspire 5740-6378 Hard Drive Replacement: paso 8, imagen 1 de 3 Acer Aspire 5740-6378 Hard Drive Replacement: paso 8, imagen 2 de 3 Acer Aspire 5740-6378 Hard Drive Replacement: paso 8, imagen 3 de 3
    • Slide the hard drive away from the connector, then lift it to remove the drive.
Conclusión
Ian Rodriguez
Miembro Desde 03/20/19
734 Reputación
5 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 5
Todo El Tiempo: 298
