Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
This guide shows how to remove the Optical Drive for the Acer Aspire 5740-5780.
Partes
No se especificaron partes.
  1. Unscrew the 2 captive screws and 3 M2.5 x L8 screws holding back cover in place. Unscrew the 2 captive screws and 3 M2.5 x L8 screws holding back cover in place.
    • Unscrew the 2 captive screws and 3 M2.5 x L8 screws holding back cover in place.
  2. Use spudger to pry open the back panel. Then lift panel off of the computer.
    • Use spudger to pry open the back panel.
    • Then lift panel off of the computer.
  3. Remove 1 M2 x L4 screw holding the drive in place with a screwdriver.
    • Remove 1 M2 x L4 screw holding the drive in place with a screwdriver.
  4. Using your hand, slowly remove the Drive from the PC.
    • Using your hand, slowly remove the Drive from the PC.
Conclusión
Gian Farrell
Miembro Desde 20/03/18
627 Reputación
6 Guías creadas
Equipo
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 229
