Saltar al contenido principal
Introducción
This guide will show you how to replace the hard drive in your Acer Aspire 5740-5780. A hard drive stores documents, applications, and the operating system for your laptop.
Indications that your hard drive is failing may include continuous crashes, error messages, or your laptop failing to turn on at all.
Before replacing your hard drive, make sure to back up all of the data stored on it so you don’t lose your documents or applications. Be sure to unplug your laptop from a power source and turn it off completely before beginning the replacement process.
Partes
No se especificaron partes.
  1. Acer Aspire 5740-5780 Hard Drive Replacement, Prepare Acer Aspire 5740-5780 for Disassembly: paso 1, imagen 1 de 2 Acer Aspire 5740-5780 Hard Drive Replacement, Prepare Acer Aspire 5740-5780 for Disassembly: paso 1, imagen 2 de 2
    • Turn the laptop off and remove the power cord.
  2. Acer Aspire 5740-5780 Hard Drive Replacement: paso 2, imagen 1 de 2 Acer Aspire 5740-5780 Hard Drive Replacement: paso 2, imagen 2 de 2
    • Press in the SD Card or the SD Card Dummy if no SD Card is there. Remove card when it pops out.
  3. Acer Aspire 5740-5780 Hard Drive Replacement: paso 3, imagen 1 de 1
    • Flip the laptop over on its face, so that the back is showing.
  4. Acer Aspire 5740-5780 Hard Drive Replacement: paso 4, imagen 1 de 1
    • Put grounding strap on one of your wrists and attach the other end to a large metal object (recommended method).
    • If you don't have a grounding strap an alternative approach is to touch a metal object that is either large or connected to the earth. Then avoid doing things that would accumulate static electricity on your body.
    • Touching the internals of your device while you aren't grounded could destroy your laptop.
  5. Acer Aspire 5740-5780 Hard Drive Replacement, Battery: paso 5, imagen 1 de 2 Acer Aspire 5740-5780 Hard Drive Replacement, Battery: paso 5, imagen 2 de 2
    • Unlock the battery by flipping a switch near the release latch.
  6. Acer Aspire 5740-5780 Hard Drive Replacement: paso 6, imagen 1 de 1
    • Slide the release latch to the left to release the battery from the PC.
  7. Acer Aspire 5740-5780 Hard Drive Replacement: paso 7, imagen 1 de 2 Acer Aspire 5740-5780 Hard Drive Replacement: paso 7, imagen 2 de 2
    • Use your hands to pry the battery free of the computer.
  8. Acer Aspire 5740-5780 Hard Drive Replacement, Back Cover: paso 8, imagen 1 de 2 Acer Aspire 5740-5780 Hard Drive Replacement, Back Cover: paso 8, imagen 2 de 2
    • Unscrew the 2 captive screws and 3 M2.5 x L8 screws holding back cover in place.
  9. Acer Aspire 5740-5780 Hard Drive Replacement: paso 9, imagen 1 de 2 Acer Aspire 5740-5780 Hard Drive Replacement: paso 9, imagen 2 de 2
    • Use spudger to pry open the back panel.
    • Then lift panel off of the computer.
  10. Acer Aspire 5740-5780 Hard Drive Replacement, Hard Drive: paso 10, imagen 1 de 1
    • Remove the one M2 x L4 screw that secures the hard drive in place.
    • Screw not shown in picture.
  11. Acer Aspire 5740-5780 Hard Drive Replacement: paso 11, imagen 1 de 1
    • Using an opening tool or your hands, slide the hard drive out of its connector.
  12. Acer Aspire 5740-5780 Hard Drive Replacement: paso 12, imagen 1 de 1
    • Lift the hard drive out of the computer.
Conclusión
2 personas más completaron esta guía.
Dwyer Deighan
Miembro Desde 25/03/18
322 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 10
Ultimos 30 días: 31
Todo El Tiempo: 991
