Saltar al contenido principal
Acer Aspire 5740-5780 Back Cover Replacement
Qué necesitas
  1. Aviso: los pasos 1-4 provienen de una guía que está marcada como "En progreso".
    Acer Aspire 5740-5780 Back Cover Replacement, Prepare Acer Aspire 5740-5780 for Disassembly: paso 1, imagen 1 de 2 Acer Aspire 5740-5780 Back Cover Replacement, Prepare Acer Aspire 5740-5780 for Disassembly: paso 1, imagen 2 de 2
    • Turn the laptop off and remove the power cord.
  2. Acer Aspire 5740-5780 Back Cover Replacement: paso 2, imagen 1 de 2 Acer Aspire 5740-5780 Back Cover Replacement: paso 2, imagen 2 de 2
    • Press in the SD Card or the SD Card Dummy if no SD Card is there. Remove card when it pops out.
  3. Acer Aspire 5740-5780 Back Cover Replacement: paso 3, imagen 1 de 1
    • Flip the laptop over on its face, so that the back is showing.
  4. Acer Aspire 5740-5780 Back Cover Replacement: paso 4, imagen 1 de 1
    • Put grounding strap on one of your wrists and attach the other end to a large metal object (recommended method).
    • If you don't have a grounding strap an alternative approach is to touch a metal object that is either large or connected to the earth. Then avoid doing things that would accumulate static electricity on your body.
    • Touching the internals of your device while you aren't grounded could destroy your laptop.
  5. Acer Aspire 5740-5780 Back Cover Replacement, Battery: paso 5, imagen 1 de 2 Acer Aspire 5740-5780 Back Cover Replacement, Battery: paso 5, imagen 2 de 2
    • Unlock the battery by flipping a switch near the release latch.
  6. Acer Aspire 5740-5780 Back Cover Replacement: paso 6, imagen 1 de 1
    • Slide the release latch to the left to release the battery from the PC.
  7. Acer Aspire 5740-5780 Back Cover Replacement: paso 7, imagen 1 de 2 Acer Aspire 5740-5780 Back Cover Replacement: paso 7, imagen 2 de 2
    • Use your hands to pry the battery free of the computer.
  8. Acer Aspire 5740-5780 Back Cover Replacement, Back Cover: paso 8, imagen 1 de 2 Acer Aspire 5740-5780 Back Cover Replacement, Back Cover: paso 8, imagen 2 de 2
    • Unscrew the 2 captive screws and 3 M2.5 x L8 screws holding back cover in place.
  9. Acer Aspire 5740-5780 Back Cover Replacement: paso 9, imagen 1 de 2 Acer Aspire 5740-5780 Back Cover Replacement: paso 9, imagen 2 de 2
    • Use spudger to pry open the back panel.
    • Then lift panel off of the computer.
Conclusión
Dwyer Deighan
Miembro Desde 03/25/18
358 Reputación
3 Guías creadas
Equipo
UMass Dartmouth, Team S3-G6, Peak Spring 2018 Miembro de UMass Dartmouth, Team S3-G6, Peak Spring 2018
UMASSD-PEAK-S18S3G6
Miembros de 3
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 8
Todo El Tiempo: 789
