Saltar al contenido principal
Acer Aspire 5734z-4836 Keyboard Replacement
  1. Acer Aspire 5734z-4836 Keyboard Replacement, Battery: paso 1, imagen 1 de 1
    • Before removing the battery, power off your laptop and disconnect the AC adapter.
    • Flip your laptop on its back so the battery is facing up and the hinges are facing away from you.
  2. Acer Aspire 5734z-4836 Keyboard Replacement: paso 2, imagen 1 de 1
    • Slide the right latch down to unlock the battery.
  3. Acer Aspire 5734z-4836 Keyboard Replacement: paso 3, imagen 1 de 2 Acer Aspire 5734z-4836 Keyboard Replacement: paso 3, imagen 2 de 2
    • Slide and hold the left latch below the battery.
    • While holding this latch in place, pry the battery up from its bottom edge.
    • Lift the old battery out of its compartment.
  4. Acer Aspire 5734z-4836 Keyboard Replacement, Keyboard: paso 4, imagen 1 de 3 Acer Aspire 5734z-4836 Keyboard Replacement, Keyboard: paso 4, imagen 2 de 3 Acer Aspire 5734z-4836 Keyboard Replacement, Keyboard: paso 4, imagen 3 de 3
    • Pinch the edges of the plastic covering above the keyboard, and pull away from the laptop until the covering pops off.
    • By using a bit of force some clicks will be heard when removing the cover.
  5. Acer Aspire 5734z-4836 Keyboard Replacement: paso 5, imagen 1 de 2 Acer Aspire 5734z-4836 Keyboard Replacement: paso 5, imagen 2 de 2
    • Pull the keyboard off gently so not to damage the keyboard ribbon cable.
    • Multiple clicks may be heard as you pull the keyboard off.
  6. Acer Aspire 5734z-4836 Keyboard Replacement: paso 6, imagen 1 de 3 Acer Aspire 5734z-4836 Keyboard Replacement: paso 6, imagen 2 de 3 Acer Aspire 5734z-4836 Keyboard Replacement: paso 6, imagen 3 de 3
    • Using a spudger or your finger, unlock the ZIF connector holding the keyboard ribbon in place by lifting the black locking lever.
    • Pull the blue keyboard ribbon cable from the ZIF connector.
    • When reinstalling a new keyboard, insert the ribbon in the same way the old keyboard's ribbon was removed.
Conclusión
2 personas más completaron esta guía.
Equipo
CSU Fullerton, Team 2-3, Bruce Fall 2016 Miembro de CSU Fullerton, Team 2-3, Bruce Fall 2016
CSUF-BRUCE-F16S2G3
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 13
Todo El Tiempo: 1,435
