Introducción
Prerequisite Only
This guide is a prerequisite to access components found in the base of the laptop. It is multi-step and involves removing several pieces and screws, so be sure to keep track of everything you remove.
Qué necesitas
Flip your laptop on its back so the battery is facing up and the hinges are facing away from you.
Pinch the edges of the plastic covering above the keyboard, and pull away from the laptop until the covering pops off.
Begin with the laptop placed on its bottom and the empty keyboard space facing you.
