Saltar al contenido principal
Acer Aspire 5542G keyboard, top case Replacement
Qué necesitas
  1. Acer Aspire 5542G keyboard, top case Replacement, keyboard, top case: paso 1, imagen 1 de 1
    • Remove all screws on the bottom of laptop. Remove HD cover (it's not necessary to remove battery and RAM cover)
  2. Acer Aspire 5542G keyboard, top case Replacement: paso 2, imagen 1 de 2 Acer Aspire 5542G keyboard, top case Replacement: paso 2, imagen 2 de 2
    • Using plastic openning sticks pick and move up top cover-panel. After disconnectiong all cables put it away.
  3. Acer Aspire 5542G keyboard, top case Replacement: paso 3, imagen 1 de 2 Acer Aspire 5542G keyboard, top case Replacement: paso 3, imagen 2 de 2
    • Raise the keyboard a little (slightly bending in order to free its plastic fixtures from the base case). Before putting the key board completely out, disconnect its flat cable from the motherboard.
  4. Acer Aspire 5542G keyboard, top case Replacement: paso 4, imagen 1 de 3 Acer Aspire 5542G keyboard, top case Replacement: paso 4, imagen 2 de 3 Acer Aspire 5542G keyboard, top case Replacement: paso 4, imagen 3 de 3
    • In order to make the top case free remove the screen screws and unplug its cables:
    • 1. remove two side screws
    • 2. unplug the connector at the bottom of the screen
    • At the bottom of laptop unplug two coax cables which pierce top case and mother board
  5. Acer Aspire 5542G keyboard, top case Replacement: paso 5, imagen 1 de 1
    • Now the top case is free to move. Detach it from the base help yourself with plastc openning sticks (don't forget to unplug flat cables).
  6. Acer Aspire 5542G keyboard, top case Replacement: paso 6, imagen 1 de 1
    • Install new top case and kewboard. Assemble all parts in reversed order.
Conclusión
3 personas más completaron esta guía.
leonid
Miembro Desde 03/11/14
245 Reputación
1 Guía escrita
3 comentarios
Hello, after completing it and turning on my notebook, the keyboard do not work. Do you know where the problem can be?
Vadja - Contestar
Hi,
if you have old keyboard at least partially working, try to put it back. If it works. probably the problem is with the new keyboard.
If the old one also doesn't work, the problem is probably with motherboard connector or software (less probable). To check the software problem, i think it's possible to load the laptop from any linux live cd or some other OS different from what s installed on your pc.
Please be aware i'm not professional pc service man and these are just common thoughts (hope helpful)
leonid - Contestar
Battery death solution please
youssef benzyane - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 14
Todo El Tiempo: 4,938
