Saltar al contenido principal
Acer Aspire 5534-1146 Hard Drive Replacement
Qué necesitas
  1. Acer Aspire 5534-1146 Hard Drive Replacement, Hard Drive: paso 1, imagen 1 de 1
    • Locate where the hard drive is located on the back side of the laptop and unscrew the two .8cm Long screws.
  2. Acer Aspire 5534-1146 Hard Drive Replacement: paso 2, imagen 1 de 1
    • Once you have have removed the back panel cover, find the hard drive’s location.
  3. Acer Aspire 5534-1146 Hard Drive Replacement: paso 3, imagen 1 de 1
    • Find and locate the two screws that are 0.8cm long that are holding the hard drive in place to the back metal plate.
    • Carefully take a PH #0 screwdriver and remove the two screws.
  4. Acer Aspire 5534-1146 Hard Drive Replacement: paso 4, imagen 1 de 1
    • Once you have unscrewed the two screws, carefully slide the hard drive the opposite direction of the screws that you just removed, slide the drive till it is free.
    • You are now ready to remove the hard drive from it’s compartment from the device.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 5
Todo El Tiempo: 496
