Saltar al contenido principal
Acer Aspire 5534-1146 Battery Replacement
Qué necesitas
  1. Acer Aspire 5534-1146 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Make sure your device is unplugged from the power source . Gently turn it over, and lay it on a flat on its face.
  2. Acer Aspire 5534-1146 Battery Replacement: paso 2, imagen 1 de 1
    • This latch locks your battery in place, it should always be locked with the exception of replacement. Slide it horizontally to the unlock position.
    • Do not break this latch, otherwise your battery will not hold in place.
  3. Acer Aspire 5534-1146 Battery Replacement: paso 3, imagen 1 de 1
    • Locate the latch that ejects the battery (top right corner) and push it to the left, so the battery can come out.
    • The battery will pull out once the latch is positioned to the left.
    • You DO NOT need to push on the ejecting latch when replacing the new battery, it will snap into place itself.
  4. Acer Aspire 5534-1146 Battery Replacement: paso 4, imagen 1 de 1
    • Push the battery forward and it will slide out, it should come out with ease. There should be a label with the part number.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 11
Todo El Tiempo: 461
