Saltar al contenido principal
Acer Aspire 5534-1096 Battery Replacement
  1. Acer Aspire 5534-1096 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Disconnect laptop from electric source prior to any repair.
    • On the bottom side of the laptop, you will unlock the safety lock by sliding it towards the left.
  2. Acer Aspire 5534-1096 Battery Replacement: paso 2, imagen 1 de 1
    • Now, you'll hold this latch to the left. Everything is unlatched. The battery should feel free.
  3. Acer Aspire 5534-1096 Battery Replacement: paso 3, imagen 1 de 3 Acer Aspire 5534-1096 Battery Replacement: paso 3, imagen 2 de 3 Acer Aspire 5534-1096 Battery Replacement: paso 3, imagen 3 de 3
    • While continuing to hold the latch in the open position, use your other hand to push the battery away from the device to remove it.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 5
Ultimos 30 días: 11
Todo El Tiempo: 319
