Saltar al contenido principal
Acer Aspire 5517-1127 Keyboard Replacement
Qué necesitas
  1. Acer Aspire 5517-1127 Keyboard Replacement, Keyboard: paso 1, imagen 1 de 1
    • Orient the device with the keyboard facing towards you.
  2. Acer Aspire 5517-1127 Keyboard Replacement: paso 2, imagen 1 de 2 Acer Aspire 5517-1127 Keyboard Replacement: paso 2, imagen 2 de 2
    • Using a metal spudger, pry open the top panel of the device as shown.
  3. Acer Aspire 5517-1127 Keyboard Replacement: paso 3, imagen 1 de 3 Acer Aspire 5517-1127 Keyboard Replacement: paso 3, imagen 2 de 3 Acer Aspire 5517-1127 Keyboard Replacement: paso 3, imagen 3 de 3
    • With the top panel remove, use the spudger to lift the keyboard out of the device as shown.
  4. Acer Aspire 5517-1127 Keyboard Replacement: paso 4, imagen 1 de 3 Acer Aspire 5517-1127 Keyboard Replacement: paso 4, imagen 2 de 3 Acer Aspire 5517-1127 Keyboard Replacement: paso 4, imagen 3 de 3
    • The keyboard ribbon is shown after removing the keyboard. There are two tabs holding the ribbon in place as shown.
    • Using your fingers, pull the tabs towards you to release the ribbon from its casing.
Conclusión
Equipo
USF Tampa, Team 17-1, Blackwell Spring 2017 Miembro de USF Tampa, Team 17-1, Blackwell Spring 2017
USFT-BLACKWELL-S17S17G1
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 11
Todo El Tiempo: 847
