Saltar al contenido principal
Acer Aspire 5517-1127 Hard Drive Replacement
Qué necesitas
  1. Acer Aspire 5517-1127 Hard Drive Replacement, Hard Drive: paso 1, imagen 1 de 1
    • Orient the laptop so that it is upside down facing away from you. The hard drive panel is on the right.
    • The two screws are at the top of the panel.
  2. Acer Aspire 5517-1127 Hard Drive Replacement: paso 2, imagen 1 de 2 Acer Aspire 5517-1127 Hard Drive Replacement: paso 2, imagen 2 de 2
    • Using a Phillips screwdriver (PH1), unscrew each screw from the panel.
    • Pull the panel away from the device as shown.
  3. Acer Aspire 5517-1127 Hard Drive Replacement: paso 3, imagen 1 de 2 Acer Aspire 5517-1127 Hard Drive Replacement: paso 3, imagen 2 de 2
    • Push the hard drive out of its housing as shown.
  4. Acer Aspire 5517-1127 Hard Drive Replacement: paso 4, imagen 1 de 1
    • The hard drive is now removed.
Conclusión
Equipo
USF Tampa, Team 17-1, Blackwell Spring 2017 Miembro de USF Tampa, Team 17-1, Blackwell Spring 2017
USFT-BLACKWELL-S17S17G1
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 7
Todo El Tiempo: 938
