Saltar al contenido principal
Acer Aspire 5517-1127 Battery Replacement
  1. Acer Aspire 5517-1127 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Orient the laptop so that it is upside down facing away from you. The battery is at the bottom.
  2. Acer Aspire 5517-1127 Battery Replacement: paso 2, imagen 1 de 1
    • The smaller switch is on the left. Move it to the unlock position.
  3. Acer Aspire 5517-1127 Battery Replacement: paso 3, imagen 1 de 1
    • Once unlocked, move the larger switch on the right to the left to release the battery.
  4. Acer Aspire 5517-1127 Battery Replacement: paso 4, imagen 1 de 1
    • When the switch is moved to the left, the battery will pop up and become removable.
Conclusión
Christopher Abrams
Miembro Desde 02/02/17
101 Reputación
1 Guía escrita
Equipo
USF Tampa, Team 17-1, Blackwell Spring 2017 Miembro de USF Tampa, Team 17-1, Blackwell Spring 2017
USFT-BLACKWELL-S17S17G1
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 7
Todo El Tiempo: 627
