Saltar al contenido principal
Acer Aspire 5349-2592 Screen Replacement
Qué necesitas
  1. Acer Aspire 5349-2592 Screen Replacement, Screen: paso 1, imagen 1 de 1
    • Open the laptop so that the screen is facing you.
  2. Acer Aspire 5349-2592 Screen Replacement: paso 2, imagen 1 de 1
    • Pull of the plastic frame of the laptop screen.
  3. Acer Aspire 5349-2592 Screen Replacement: paso 3, imagen 1 de 1
    • Unscrew the 1/4'' screws at each of the corners using a Phillips screwdriver
    • Pull off the screen from the device. If necessary, you may use a bezel provided by the iFixit tool kit.
    • Handle the Acer 5349-2592 LCD hinges with care as they are delicate.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 7
Ultimos 30 días: 15
Todo El Tiempo: 586
