Saltar al contenido principal
Acer Aspire 5349-2592 Keyboard Replacement
Qué necesitas
  1. Acer Aspire 5349-2592 Keyboard Replacement, Battery: paso 1, imagen 1 de 1
    • Turn the laptop over so that the back is facing you.
  2. Acer Aspire 5349-2592 Keyboard Replacement: paso 2, imagen 1 de 1
    • Push the laptop battery release lock.
  3. Acer Aspire 5349-2592 Keyboard Replacement: paso 3, imagen 1 de 1
    • Now that the Acer-Aspire 5349-2592 laptop battery is unlocked, press the battery release button down.
  4. Acer Aspire 5349-2592 Keyboard Replacement: paso 4, imagen 1 de 1
    • Holding down the laptop battery release button, gently pull the battery away from the laptop.
  5. Acer Aspire 5349-2592 Keyboard Replacement, Keyboard: paso 5, imagen 1 de 2 Acer Aspire 5349-2592 Keyboard Replacement, Keyboard: paso 5, imagen 2 de 2
    • Open the laptop and locate the top edge of the keyboard.
    • Use a flathead screwdriver to gently pry the keyboard upward and lift it out of the laptop.
  6. Acer Aspire 5349-2592 Keyboard Replacement: paso 6, imagen 1 de 1
    • Use a flathead screwdriver to gently lift the clamp upward and remove the cable.
  7. Acer Aspire 5349-2592 Keyboard Replacement: paso 7, imagen 1 de 1
    • The keyboard is now disconnected and can be safely removed.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 13
Todo El Tiempo: 995
