Saltar al contenido principal
Acer Aspire 5349-2592 Hard Drive Replacement
Qué necesitas
  1. Acer Aspire 5349-2592 Hard Drive Replacement, Battery: paso 1, imagen 1 de 1
    • Turn the laptop over so that the back is facing you.
  2. Acer Aspire 5349-2592 Hard Drive Replacement: paso 2, imagen 1 de 1
    • Push the laptop battery release lock.
  3. Acer Aspire 5349-2592 Hard Drive Replacement: paso 3, imagen 1 de 1
    • Now that the Acer-Aspire 5349-2592 laptop battery is unlocked, press the battery release button down.
  4. Acer Aspire 5349-2592 Hard Drive Replacement: paso 4, imagen 1 de 1
    • Holding down the laptop battery release button, gently pull the battery away from the laptop.
  5. Acer Aspire 5349-2592 Hard Drive Replacement, Back plate: paso 5, imagen 1 de 1
    • Remove all of the screws located on the back of the laptop using your Phillips #0 screwdriver.
  6. Acer Aspire 5349-2592 Hard Drive Replacement: paso 6, imagen 1 de 1
    • Pry open the backplate using the iFixit opening tool and remove the backplate from the device.
  7. Acer Aspire 5349-2592 Hard Drive Replacement, Hard Drive: paso 7, imagen 1 de 1
    • Remove the the pin strip.
  8. Acer Aspire 5349-2592 Hard Drive Replacement: paso 8, imagen 1 de 1
    • Remove the two screws from the caddy using the Phillips #0 screwdriver.
  9. Acer Aspire 5349-2592 Hard Drive Replacement: paso 9, imagen 1 de 1
    • Slide out the caddy.
  10. Acer Aspire 5349-2592 Hard Drive Replacement: paso 10, imagen 1 de 3 Acer Aspire 5349-2592 Hard Drive Replacement: paso 10, imagen 2 de 3 Acer Aspire 5349-2592 Hard Drive Replacement: paso 10, imagen 3 de 3
    • Slightly lift up the hard drive and pull it out from the device.
Conclusión
3 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 5
Ultimos 30 días: 19
Todo El Tiempo: 1,752
