Saltar al contenido principal
Acer Aspire 5349-2592 Fan Replacement
Qué necesitas
  1. Acer Aspire 5349-2592 Fan Replacement, Battery: paso 1, imagen 1 de 1
    • Turn the laptop over so that the back is facing you.
  2. Acer Aspire 5349-2592 Fan Replacement: paso 2, imagen 1 de 1
    • Push the laptop battery release lock.
  3. Acer Aspire 5349-2592 Fan Replacement: paso 3, imagen 1 de 1
    • Now that the Acer-Aspire 5349-2592 laptop battery is unlocked, press the battery release button down.
  4. Acer Aspire 5349-2592 Fan Replacement: paso 4, imagen 1 de 1
    • Holding down the laptop battery release button, gently pull the battery away from the laptop.
  5. Acer Aspire 5349-2592 Fan Replacement, Back plate: paso 5, imagen 1 de 1
    • Remove all of the screws located on the back of the laptop using your Phillips #0 screwdriver.
  6. Acer Aspire 5349-2592 Fan Replacement: paso 6, imagen 1 de 1
    • Pry open the backplate using the iFixit opening tool and remove the backplate from the device.
  7. Acer Aspire 5349-2592 Fan Replacement, CD / DVD Drive: paso 7, imagen 1 de 1
    • Unscrew the single screw on the DVD drive with your Phillips #0 screwdriver.
  8. Acer Aspire 5349-2592 Fan Replacement: paso 8, imagen 1 de 1
    • Gently lift the drive up and remove it from the pin.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 8
Todo El Tiempo: 290
