Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Introducción
This guide is simple and it will show how to replace RAM on your Acer Aspire 5334-2581. RAM usually helps boost the computer speed and functionality.
Partes
No se especificaron partes.
  1. Please make sure your device is unplugged . Turn it over slowly, and place it on a flat surface.
    • Please make sure your device is unplugged . Turn it over slowly, and place it on a flat surface.
  2. This latch holds your battery in place, it should always be locked. Make sure to unlock this piece.
    • This latch holds your battery in place, it should always be locked. Make sure to unlock this piece.
    • Do not break this latch, otherwise your battery will not hold in place.
  3. Kits para Nintendo Switch
    Una solución rápida para volver al juego
    Comprar kits de Switch
  4. Locate the eject latch and push it so the battery can come out.
    • Locate the eject latch and push it so the battery can come out.
    • The battery will lift up once you have pushed the latch.
    • You DO NOT need to adjust the latch when replacing the new battery, because it just snaps in place.
  5. Lift the battery up, and it should just come right off.  You should see the label with the part number.
    • Lift the battery up, and it should just come right off. You should see the label with the part number.
  6. Remove the phillips screw
    • Remove the phillips screw
    • then take away the cover
  7. Push the marked claws to the side in order to make the RAM free.
    • Push the marked claws to the side in order to make the RAM free.
    • To remove the RAM just pull it in the shown direction.
    • Take extra care when removing the RAM, you do not want to damage the placeholder for the RAM.
Conclusión
Una persona más ha completado esta guía.
Equipo
UMass Dartmouth, Team 1-2, Catania Fall 2016 Miembro de UMass Dartmouth, Team 1-2, Catania Fall 2016
UMASSD-CATANIA-F16S1G2
3 Miembros
5 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 130
