Saltar al contenido principal
Acer Aspire 5334-2581 Battery Replacement
  1. Acer Aspire 5334-2581 Battery  Replacement, Battery: paso 1, imagen 1 de 1
    • Please make sure your device is unplugged . Turn it over slowly, and place it on a flat surface.
  2. Acer Aspire 5334-2581 Battery  Replacement: paso 2, imagen 1 de 1
    • This latch holds your battery in place, it should always be locked. Make sure to unlock this piece.
    • Do not break this latch, otherwise your battery will not hold in place.
  3. Acer Aspire 5334-2581 Battery  Replacement: paso 3, imagen 1 de 1
    • Locate the eject latch and push it so the battery can come out.
    • The battery will lift up once you have pushed the latch.
    • You DO NOT need to adjust the latch when replacing the new battery, because it just snaps in place.
  4. Acer Aspire 5334-2581 Battery  Replacement: paso 4, imagen 1 de 1
    • Lift the battery up, and it should just come right off. You should see the label with the part number.
Conclusión
Equipo
UMass Dartmouth, Team 1-2, Catania Fall 2016 Miembro de UMass Dartmouth, Team 1-2, Catania Fall 2016
UMASSD-CATANIA-F16S1G2
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 6
Todo El Tiempo: 289
