Saltar al contenido principal
Acer Aspire 5251-1513 Hard Drive Replacement
Qué necesitas
  1. Acer Aspire 5251-1513 Hard Drive Replacement, Battery: paso 1, imagen 1 de 1
    • Turn over the laptop so the back is facing up.
  2. Acer Aspire 5251-1513 Hard Drive Replacement: paso 2, imagen 1 de 2 Acer Aspire 5251-1513 Hard Drive Replacement: paso 2, imagen 2 de 2
    • Next to the battery is a switch with a lock symbol on it.
    • Unlock the switch by sliding it to reveal a red unlock symbol.
  3. Acer Aspire 5251-1513 Hard Drive Replacement: paso 3, imagen 1 de 2 Acer Aspire 5251-1513 Hard Drive Replacement: paso 3, imagen 2 de 2
    • Pull the other switch completely while the red unlock symbol is still present. The battery pack should pop up a bit.
  4. Acer Aspire 5251-1513 Hard Drive Replacement: paso 4, imagen 1 de 2 Acer Aspire 5251-1513 Hard Drive Replacement: paso 4, imagen 2 de 2
    • Remove the battery pack via the indentation at the top of the battery in between the two switches.
  5. Acer Aspire 5251-1513 Hard Drive Replacement, Hard Drive: paso 5, imagen 1 de 1
    • Unscrew the two 8.6 mm screws using a Phillips #0 screwdriver.
  6. Acer Aspire 5251-1513 Hard Drive Replacement: paso 6, imagen 1 de 2 Acer Aspire 5251-1513 Hard Drive Replacement: paso 6, imagen 2 de 2
    • Use a spudger or plastic opening tool to lift the panel up. Then remove the panel entirely with your hands.
  7. Acer Aspire 5251-1513 Hard Drive Replacement: paso 7, imagen 1 de 2 Acer Aspire 5251-1513 Hard Drive Replacement: paso 7, imagen 2 de 2
    • Slide the hard drive to the left until it clicks and then pull it out completely.
  8. Acer Aspire 5251-1513 Hard Drive Replacement: paso 8, imagen 1 de 3 Acer Aspire 5251-1513 Hard Drive Replacement: paso 8, imagen 2 de 3 Acer Aspire 5251-1513 Hard Drive Replacement: paso 8, imagen 3 de 3
    • Unscrew the four 3.6 mm screws on either side of the casing with the Phillips #0 screwdriver.
    • Remove the hard drive out of its casing.
    • Be Gentle with the hard rive, only touch the edges.
Conclusión
Una persona más ha completado esta guía.
Gicely Rodriguez
Miembro Desde 02/14/19
1,029 Reputación
5 Guías creadas
Equipo
USF Tampa, Team S1-G6, Leahy Spring 2019 Miembro de USF Tampa, Team S1-G6, Leahy Spring 2019
USFT-LEAHY-S19S1G6
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 3
Ultimos 30 días: 9
Todo El Tiempo: 599
