Saltar al contenido principal
Acer Aspire 5100 Hard Drive Replacement
Guía Archivada
Esta guía se mantiene únicamente para fines históricos. Utiliza la última versión de la guía para llevar a cabo tu reparación.
Qué necesitas
  1. Acer Aspire 5100 Hard Drive Replacement, Battery: paso 1, imagen 1 de 1
    • Make sure the laptop is turned off and unplugged.
    • Flip the laptop over so the audio jacks are facing you.
    • Unlock the battery by sliding the button (located above the battery) towards the outer edge of the computer. When you feel the battery release and pop up, gently pull the battery from its compartment.
  2. Acer Aspire 5100 Hard Drive Replacement, Hard Drive: paso 2, imagen 1 de 1
    • Start by locating the small panel directly to the right of the battery.
  3. Acer Aspire 5100 Hard Drive Replacement: paso 3, imagen 1 de 1
    • Remove the two screws securing the panel.
  4. Acer Aspire 5100 Hard Drive Replacement: paso 4, imagen 1 de 1
    • Grip the right side of the hard drive and pull towards the right side of the computer
    • Remove the mounting bracket from the old hard drive.
    • Transfer the mounting bracket to the new hard drive and install the new drive.
Conclusión
Una persona más ha completado esta guía.
iDeleted
Miembro Desde 07/07/10
2,101 Reputación
39 Guías creadas
Un comentario
didnot give good information for newly observed person
venki - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 3,215
