Introducción
If your device's screen display is distorted, cracked, flickers, or has tiny dots, replacing the screen will probably solve these issues.
Qué necesitas
Position the laptop so you have a clear view of the front of the screen.
Remove the two screw covers at the bottom sides of the screen casing using a flat tool.
Remove the two 5.0 mm Phillips screws. They will be directly underneath the screw covers.
To reassemble your device, carefully follow these instructions in reverse order.
2 personas más completaron esta guía.
