Saltar al contenido principal
Acer Aspire 4743-6481 Ram Card Replacement
Qué necesitas
  1. Acer Aspire 4743-6481 Ram Card Replacement, Battery: paso 1, imagen 1 de 1
    • Turn over the laptop to view the underside.
  2. Acer Aspire 4743-6481 Ram Card Replacement: paso 2, imagen 1 de 1
    • Use tweezers (or a similar tool) to slide the orange push pin. To release the battery, push it to the left.
  3. Acer Aspire 4743-6481 Ram Card Replacement: paso 3, imagen 1 de 1
    • You can lift the battery up and out now.
  4. Acer Aspire 4743-6481 Ram Card Replacement, RAM Card: paso 4, imagen 1 de 1
    • Remove three 7.0 mm screws with a Phillips head screwdriver from the back panel to gain access to the RAM cards.
  5. Acer Aspire 4743-6481 Ram Card Replacement: paso 5, imagen 1 de 1
    • Place the device with the battery side facing up, as shown on the picture.
    • After removing the back panel, you will see the RAM cards located to the right.
  6. Acer Aspire 4743-6481 Ram Card Replacement: paso 6, imagen 1 de 1
    • You should notice a silver tab on each side of the RAM card. Push each tab away at the same time to detach the card.
  7. Acer Aspire 4743-6481 Ram Card Replacement: paso 7, imagen 1 de 1
    • If done successfully, the RAM should pop out and you can lift it out with no effort.
Conclusión
AL-Moatasem
Miembro Desde 02/22/17
101 Reputación
1 Guía escrita
Equipo
USF Tampa, Team S5-G1, Lacy Spring 2017 Miembro de USF Tampa, Team S5-G1, Lacy Spring 2017
USFT-LACY-S17S5G1
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 10
Todo El Tiempo: 706
