Saltar al contenido principal
Acer Aspire 4743-6481 DVD Drive Replacement
Qué necesitas
  1. Acer Aspire 4743-6481 DVD Drive Replacement, Battery: paso 1, imagen 1 de 1
    • Turn over the laptop to view the underside.
  2. Acer Aspire 4743-6481 DVD Drive Replacement: paso 2, imagen 1 de 1
    • Use tweezers (or a similar tool) to slide the orange push pin. To release the battery, push it to the left.
  3. Acer Aspire 4743-6481 DVD Drive Replacement: paso 3, imagen 1 de 1
    • You can lift the battery up and out now.
  4. Acer Aspire 4743-6481 DVD Drive Replacement, DVD Drive: paso 4, imagen 1 de 1
    • Remove the 7.0 mm screw, circled in the picture, using a Phillips head screwdriver.
  5. Acer Aspire 4743-6481 DVD Drive Replacement: paso 5, imagen 1 de 1
    • Once the screw is removed, the DVD drive should easily slide out
  6. Acer Aspire 4743-6481 DVD Drive Replacement: paso 6, imagen 1 de 1
    • Remove the drive completely.
  7. Acer Aspire 4743-6481 DVD Drive Replacement: paso 7, imagen 1 de 2 Acer Aspire 4743-6481 DVD Drive Replacement: paso 7, imagen 2 de 2
    • Face the side of the DVD drive that connects to the laptop and remove the 3mm screw with a Phillips head screwdriver.
    • Put the screw and the bracket to the side as you may need it for your replacement.
Conclusión
Una persona más ha completado esta guía.
Filippo Santoro
Miembro Desde 02/15/17
240 Reputación
2 Guías creadas
Equipo
USF Tampa, Team S5-G1, Lacy Spring 2017 Miembro de USF Tampa, Team S5-G1, Lacy Spring 2017
USFT-LACY-S17S5G1
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 10
Todo El Tiempo: 661
